Knock sensor madness on '94 850 Turbo
Bflat
Post by Bflat »
I purchased high-milage (300,000km) '94 850 Turbo wagon (Canadian) about six months ago. It is extremely clean and checked out well with no problems on a pre-purchase mechanical.
The engine check light came on soon after I brought it home. Had it reset several times to verify code fault - initial and subsequent codes read oxygen sensor - sensor replaced. Not that long after the check light was on again. Code said knock sensor. Reset several times - always read knock sensor. Replaced knock sensor. Advised to start using highest octane fuel - done. Light was soon on again. Several resets. Codes always read knock sensor. Last time in, mechanic at my Volvo dealership said he thought he discovered a bad connection. Reset. Light on again a week later. Shop now suggests I bring it back and see if it's the engine management module.
Throughout this madness it has continued to run flawlessly. I'm thinking there was never a problem with the knock sensor ($500), or anything else, in the first place and that the system is just super-finicky after 300,000km. Am going stark raving loonie and although I still enjoy driving it, am cursing the day I bought this crate.
Is there some way to disconnect the light and is that a good ideas?
Any other thoughts?
White850Turbo
Year and Model:
Post by White850Turbo »
Volvo updated the way that the knock sensors work for the 850's. They sell a service kit which includes the newer and updated design. Do you happen to know if this kit was installed?
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
Bflat
Post by Bflat »
Thanks for responding Sean.
Yes, the new sensor kit they installed was one of the newer modified ones. Is that significant?
Bflat
Post by Bflat »
A new development - today, as I was driving, the light went off.
I seem to remember reading in one of the posts (I can't find it now) that the light will reset itself after a period of time.
Is this correct?
Anyone?
White850Turbo
Year and Model:
Bflat wrote:A new development - today, as I was driving, the light went off.
Is this correct?
Anyone?
After a certain number of trouble free driving cycles, the light will turn itself off depending on the nature of the code.
-Sean
Bflat
Post by Bflat »
Thanks Sean.
I'm curious - what is an 854 (as opposed to an 850) and how has it been modified?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Four door (sedan) as opposed to 855, five door (wagon).
Purely a user designation. I don't believe Volvo badged 850s as "854" or "855", although I met a guy with an 855 who had a 855 badge made. His 855 was recently in a Swedespeed.com feature. The Volvo has Mercedes wheels.
Also -> Amazon link
White850Turbo
Year and Model:
Bflat wrote:Thanks Sean.
It's modified enough to embarass owners of LT1 V8 Trans-Ams, SS Camaro's, and make it into the November issue of GrassRoots Motorsports Magazine :D .
Here's a recent pic of it: Image
-Sean
Guest
Post by Guest »
That's one lean, mean machine!
Bflat
rush
Year and Model:
Post by rush »
what is effected by "Knock sensor" i got same error code, but car works fine accept engine light is on?
