Around the window
jolepatrol
Year and Model: 1999 S80 2.9L
Around the window
Post by jolepatrol »
So the black trim is starting to peel around the windows. I was wondering if anyone has tried to take this off, as it seems that it's painted the same color underneath. Some of the S60's have no trim and just matching paint, and it looks a lot better. I've been trying to decide if I should do this or not :S Any suggestions?
This is just one part, it's all over on all sides :[
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
I think it's not so bad, yet.
Use a black marker (permanent) to mask it at this stage. When the situation gone worst (probably after a couple ot years...) you may think about some paint job.
You decide :)
GOOD LUCK
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
jolepatrol
It's just like a huge sticker, it's held on with some sort of adhesive, but idk how strong it is. :evil: I don't want to rip half of it off while the other half is going to be glued tight.
yuckuJackD
Uncle VADIS said:
Upper note is for front, bottom is for back stripes.
I'm able to check the prices online for the local bulgarian dealer, but i don't know about your dealer where you can make such a check...
GOOD LUCK
yuckuJackD
Removing decorative tape.pdf
(74.04 KiB) Downloaded 210 times
Installing decorative tape, external.pdf
(295.69 KiB) Downloaded 178 times
Installing decorative tape, internal.pdf
(267.74 KiB) Downloaded 234 times
Use the same method for the rear door.
GOOD LUCK
jolepatrol
GOOD LUCK
Thank you so much! I assumed it needed to be heated, but I wasn't for sure. I'll see if I have time this weekend to finally do it.
yuckuJackD
Remove all plastik and rubber materials before heating!
VADIS said you have ro remove even the window, but... if you wish don't remove it (at your own risk of course). But remove the door panels!
If you need a manual for removing pannels and/or window just ask and I'll post them for you.
GOOD LUCK
