2000 S80 T6 215,000km: Started misfiring slightly this afternoon (engine was at normal running temperature at the time) then took it for a spin around the block and misfiring increased with flashing orange "check engine" light. I turned the car off, then restarted...misfiring continued and "check engine" changed to solid orange. Smell evident inside cabin, but not in engine.
Am due at mechanic's Monday to hopefully confirm wet carpet on drivers side is from leaking "o-rings" not from heater core itself. Now this! Any ideas what might be the cause of the misfiring and what the possible costs might be? I can't bear the thought of a major expense plus a possible heater core.
I've noticed (for years) hesitation/misfiring when starting out on cool mornings, that goes away after a minute and doesn't return until the next day. Possibly linked to today's problem?
Any thoughts/comments would be much appreciated! Thanks!
Misfiring and smelly!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
The flashing check engine light means that it's misfiring for sure. Pull the codes to find out which cylinders, then check the coil packs on those cylinders - you're probably going to have to replace more than one.
The smell is from raw gas being pushed through the catalytic converter.
'98 S70 T5
2016 Chevy Cruze Premier
