Hi
V70 turbo 2001
Repacing Frount O2 with a universal Bosh 15733
can not get electric clip (plastic clip that holds O2 wire to wiring harness) loose
It is at arms length on driverside . have been poking at it with screwdriver but can't get it loose
press down or pull up?
oxygen sensor
JDS60R
- Been thanked: 3 times
Bosch 17070 looks like it has a clip on one side. You press the tab farthest away from the harness to release/lift the tab over the lock. Then pull
- 17070.jpg (31.34 KiB) Viewed 511 times
Retired
