V70 Engine Vibrations around 2000 rpm
AssenTT
Year and Model:
Post by AssenTT »
Hi,
I have a V70 from 2001 with the 140 hp engine. Around 2000 rpm I have an engine vibration that sounds a bit like the slipping of a belt. Rarely when the car is standing still and you keep the engine at 2000 rpm, but almost always when the car is moving in second, third and fourth gear. Certainly when I accelerate and push the engine through the 2000 rpm area...
The dealer has replaced the belt and everything that is driven by the belt, and he can not hear anything when the belt is completely removed..
Who van help me to solve this mistery??? :(
starman1
Post by starman1 »
I have same problem with my S60/01 170hp - engine vibration between 2000-2100rpm. My dealer checked my car and didn
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
Worn engine mount?
Also -> Amazon link
starman1
Post by starman1 »
Yes, it seems to be worn engine mounts. Engine is "dancing"
... So, tell me please, how many mounts have I to change?
I see one upper mount, and two under engine - what next?
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
There's are 4 of them....Front, Rear, Right and Upper. You're probably not seeing the rear as there is a metal piece covering it from view...it's on the subframe left of center towards the driver's side.
starman1
Post by starman1 »
Thank you very much,
I
