2001 v70xc 92k, 2nd ETM just failed
etm
etm
Greetings to all -
- just replaced with Xemodex,
at the time of new ETM install, replaced MAF with new BOSCH oem from FCP as well as IAT sensor and MAP/BPS sensor - car drove good, noticed no problems at initial test drive of about 5 miles. Restarted after a couple of hours the car now has eratic idle, hesitates as if about to stall an occurs only when the AC is on, while in D with the brake applied. Note when the AC is off when in D and brake applied these symptoms are not present. Thanks in advance for any suggestions or feedback.
JRL
- Year and Model: Several
- Been thanked: 16 times
Call XeMODex
JRL
Call XeModex
- 3606 Views
Last post by ajwsurfer
- 4031 Views
Last post by antonevane
