USE OEM ONLY for these:
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hmm let's see now. What parts should we use as OEM only? This list may help others save themselves a LOT of repeating repairs.
Volvo '93-'00 850/V70
Front control arms
Cam seals
Sachs or Bilstein or Koni shocks only
Spring seats
Flame trap kits
If anyone would like to contribute to this thread please do so, or relate experiences where non-OEM have disappointed.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I'd say anything electrical i.e sensors:
-Mass Airflow Sensor
-Engine Coolant Temp Sensor
-Oxygen Sensors (OEM/proper Bosch equivalent)
However, I did replace my front control arms with FCP aftermarket ones, and have had no issues for 13,000+ miles. They seem to be very high quality.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Glencoeteen
Year and Model: 00 V70R
Post by Glencoeteen »
Volvo Plug's- Yes I understand that others have had good experiences with other brands, but to be honest its just not worth wasting time dealing with misfires due to plugs.
Cap and Rotor, Stick with Bosch, trust me you will thank me and others who agree that These car's dislike anything other than OEM parts.
Oil Filters are another big one that I have personally noticed, anything than Mahle or MANN are just total garbage for these motor's.
I Highly recommend using Mobil-One Fully Synthetic oil mainly for Turbo charged models but I run it in every car I own, I have never had oil burn or leak since! and it hold's up to my "moments of total madness" :twisted:
There are ton's of other things that you really should not stray from, but I will let others have their point of views said. :mrgreen:
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Tune up items commonly substituted to great regret:
Ignition Wires - Bougicord (OEM) or Genuine Volvo only, avoid aftermarket wires. The horsepower crowd will argue back, but unless you have a thoroughly modified engine including ECU work, don't play around here.
Spark Plugs - some stay strictly Genuine Volvo, others say OEM or Bosch Copper is fine. NA are a little more tolerant than the Turbos, I've had acceptable result from Bosch Platinum +2's - but honestly wouldn't try them again.
Oil filters - Mann only is advised, any aftermarket MUST have an internal check valve, K&N and Mobil 1 will suffice. Avoid the Fram Orange Can of Death like it's the plague - actually, that's exactly what they are.
5 others that came and went
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
ecbsykes wrote:I'd say anything electrical i.e sensors:
You can buy a Bosch MAF for less than half the price of a Volvo branded one
AND IT'S THE EXACT SAME PIECE! BOSCH MAKES THEM FOR VOLVO.
Don't forget strut bearing plates, should be OEM only
kcodyjr
Post by kcodyjr »
JRL alludes to a really important point - OE versus OEM.
Most of the time, OE (Volvo blue box, aka Genuine Volvo) and OEM (same part direct from mfr) are equivalent.
The trouble comes in making sure you've got the right one.
So, in this case, ecbsykes and JRL are both right - OEM MAF is just fine. Aftermarket is not a good idea.
MatDesign84
Year and Model: 1997,855 T5
Post by MatDesign84 »
plug wires (bosch) (seems like IPD and other brands give lots of trouble in reviews I have read)
+1 on Spark Plugs
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
FlyingVolvo
Yeah, I got my new one from eeuroparts.com for $90!
http://www.eeuroparts.com/Main/PartDeta ... id=8670263
Same thing!
2023 V60 T8 PE
Been thanked: 504 times
Post by cn90 »
kcodyjr wrote:...
---> Spark Plugs: I have been using Bosch Copper Plugs for the last 10 years, no issues whatsoever.
---> Oil Filter: Yes Mann and Mahle are good.
But I have been using Bosch Oil Filter (Bosch #3321) and no issues.
The Internal Anti-drain back valve is not important in the 850, S/V70 series because the oil filter is mounted upside down, so when engine is stopped, oil is not drained out.
The By-Pass Valve is present in all 3: Mann, Mahle, and Bosch 3321.
Post by cn90 »
JRL wrote:...Don't forget strut bearing plates, should be OEM only
Actually Sachs is the OEM : $77/each.
I have had this for 2 years now, no issues.
