99 s80 rough starting
Tennessee S80
Year and Model: 99 s80
Post by Tennessee S80 »
My s80 has developed a "rough starting" problem. If the car sits parked for a few hours or overnight. When I start it, it turns over. Begins to run, but "shudder" for 3 - 6 seconds and then runs fine. While I'm out driving if I go into a store and come out. The car will start fine without any problems.
I just had the fuel pump replaced, it had a pin hole leak, I thought that this would fix the problem. It didn't. The car has 104k miles on it. So I'm thinking possible timing belt related.
Any ideas.
Thanks in advance
Tennessee
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I doubt a timing belt problem. Either the timing belt is there and working or it is snapped and nothing works. However, you are due for a belt change at 105,000 miles.
This would appear to be a cold start problem as you don't have trouble with the engine warm. As you have had the fuel pump replaced recently it is possible that you are having a fuel pressure problem. Do you have a check engine light on?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Tennessee S80
No, I don't have a check engine light on. Other than the "rough start" everything seems normal.
hansenjg
Year and Model: 2011 XC60 3.2
Post by hansenjg »
If this is a fuel injected engine, it could be a leaking fuel injector. As the engine sits over time, fuel drips into the cylinder (or two or three). Then when you start it, that excess fuel causes a rich condition for a few seconds before the fuel burns off. You might get some heavier smoke out the exhaust during that time too. I was looking for a thread about this because I was going to ask about my 2000 C70 exhibiting the same symptoms. I think it's an injector leak, but if anyone has a better idea I'm all ears!
John
2004 C70 Ragtop w/2.4L LPT 65K miles (wife dd)
2003 XC 70 with 2.5L Turbo, 195K miles (my dd)
Parts Car: 2000 C70 Ragtop w/2.3L Turbo, died at 200K miles (water pump siezed. took out timing belt)
daytrader1981
Year and Model: 1999 S80
Post by daytrader1981 »
I am having the same issue with my 99 s80 non-turbo. Did you ever get this fixed and what was the problem?
hansenjg
Post by hansenjg »
Mine cured itself. I must have had a little dirt or something in one injector, that cleared itself. Wish I could be more helpful, Daytrader!
John
schmidm90
Year and Model: 2000 V70 XC AWD
Post by schmidm90 »
I have a 2000 V70XC and I replaced the fuel pump around 7k miles ago. It ran great until 2 days ago. It has been tough to start, but once it is running it runs great. I have read that it is probably a problem with the fuel system losing pressure. I have also seen people have added an inline check valve. It will still start, but it needs to be cranked 5-7more seconds before it starts. Any help would be appreciated. I havent seen any visible fuel leaks at the car and dont smell gasoline anywhere around the engine.
I also dont have any CEL on.
Thanks!
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
uncletom
Post by uncletom »
I,m sure you have found your answer to your problem by now but for other viewers this may be there answer. My 99 S80 2.9 had the very same symptoms and was the brake booster leaking down after a few hours. Upon re starting the vacuum drawn into the engine to arm the booster was feeding the air fuel a very lean condition because the additional air was not being drawn past MAF therefore a bad fuel air mixture for a few seconds. The repair is replace the booster.
Hope this may help someone.
99 S80 2.9 / 99 Land Rover disco 1 / 86 Alfa Romeo Spider veloce
