rear window washer pump
chrito
Post by chrito »
My rear window washer does not appear to be working on my 98 v70T5. The washer fluid level is full. Any suggestions as to what to try next.
Thanks
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Clogged washer hose...look for the "T" connector under the hood, near or up under the windshield area....hope this helps. Take it apart and clean with a pipe cleaner. If this doesn't get it, then it's clogged somewhere else or the pump motor is bad.
