My rear window washer does not appear to be working on my 98 v70T5. The washer fluid level is full. Any suggestions as to what to try next.
Thanks
rear window washer pump
- Has thanked: 17 times
- Been thanked: 35 times
Clogged washer hose...look for the "T" connector under the hood, near or up under the windshield area....hope this helps. Take it apart and clean with a pipe cleaner. If this doesn't get it, then it's clogged somewhere else or the pump motor is bad.
- 36 Replies
- 21800 Views
Last post by StickyPocket
- 773 Views
Last post by freedomfries
