Yet Another Cruise Control Question
1996 - 2004 S40
1996 - 2004 V40
vaniwaar
Year and Model: 2001 S40
Post by vaniwaar »
I have a 2001 S40 and my cruise control does not work. I switch it on, the light on the dash comes on and then I press '+' to attempt to engage it but nothing happens. I have tried pulling up on the brake pedal while simultaneously pressing the '+' button and the cruise does engage. This leads me to believe that either the switch has gone bad or the vacuum line is bad or disconnected. I verified that the vacuum line is connected at the switch but don't know where to look under the hood. I would also think that, if the vacuum line were disconnected, the vacuum pump would continually run.
This is just a minor annoyance right now and I don't want to purchase a new switch unless I know with a high likelihood that the switch is what is wrong. Thoughts?
--Ron
JDS60R
Been thanked: 3 times
Post by JDS60R »
Use a meter to test the switch
Retired
vaniwaar
Post by vaniwaar »
JDS60R wrote:Use a meter to test the switch
I wouldn't quite know how to do that. I have an electrical meter I use rarely and usually is is for something trivial...
--Ron
hammertime
Year and Model: '04 XC90, '07 XC70
Post by hammertime »
If your cruise engages when you pull back on the brake pedal, it's the switch. It likely only needs adjusting. Get a good grip on it and push it toward the brake pedal arm. On one of mine it clicked into another groove making it tighter. On one of my other cars I placed a bread bag clip with two sided tape on the arm under the switch. It provided enough preasure to activate the switch.
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
