headlights angle off
mustangprophecy
- Year and Model: 2001
i own a 2001 volvo S60 2.4T i finally got around to adjusting the headlights i can adjust one of them but not the other i haven't looked at it much cause i work 7 days a week but i was curious if something needs to be reattached or will i have to pull and replace the whole headlight assembly?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
When I got my S70, one of them pointed way off into the trees. The reflector in mine has a little ball joint it sits on that allows it to pivot around - it had just come off of that.
On mine, the plastic lens pops off the front with just a few retaining clips and will let you gain access to the inside. I don't know how the newer ones are, but look for something similar.
'98 S70 T5
2016 Chevy Cruze Premier
mustangprophecy
well i fixed it but im not sure how i tried pulling the headlight cover off to look for the reflector you were talking about nothing would come off easily so i thought maybe pull the whole headlight and see if i could crack it open to look for it still wouldn't come out. so i kicked it out of anger but then i thought lets try the adjuster one more time and bam it moved so either i'm stupid and didn't get it the first time or i made something catch that was suppose to thanks for your help.
- 3119 Views
Last post by ShadowDancer
- 1739 Views
Last post by wizechatmgr
