airbag removal Topic is solved
Francis
Post by Francis »
Do I disconnect the plastic piece going into the the unit(arrow) or the two screws(circles) I'm in the process of replacing the horn contacts. Image
Guest
Post by Guest »
Image[/url]
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
- disconnect the battery
- turn the wheel all the way to one side. There is a hole on the back of the wheel, inside there is a t-30 torx screw. Remove that.
- turn all the way to the other side. Remove torx screw.
- airbag is now loose. Unhook electrical connector and put airbag in a safe place. (I put mine on the kitchen counter while I worked. When I went back inside my 16 year old son was juggling the airbag. Really.)
- look for broken red plastic parts. I think they are on the back side of the frame, kind of hard to see.
from https://www.matthewsvolvosite.com/tips.php#horn
Without being in there myself, I don't know what he meant by "Unhook electrical connector". Sorry I can't offer my direct assistance. Hope that helps.
Also -> Amazon link
Volvo850Racer
Year and Model:
Post by Volvo850Racer »
My experiance with getting the screws out was not fun. Be sure to get that torxs tool in all the way and don't be suprised if you really have to put the man on them to break them loose.
Mark
Mark
95 850GLT Wagon 84k Sway bar mod
94 850 resurrected from salvage Sold
93 850GLT Volvo bought it back
86 740GLT Traded
Guest
Post by Guest »
the arrow. just pull the white connector off.
