1999 S70 w/ Bad Alternator
Guest
Post by Guest »
Hello,
I have a 1999 S70 (79,000 miles) with the base 2.4 L I5 engine. For about 3-4 years now, the vehicle has made a chirping noise, which has consistently gotten worse. Starting the car in the morning is difficult because the vehicle cranks for a long time and when it starts, all of the lights flicker and the engine runs very rough for 3-4 seconds (it almost feels like it's going to stall). I replaced the battery and serpentine belt about 6 months ago but the problem is still there so I'm pretty sure that the alternator is the culprit. I would appreciate it if someone could provide me with the procedure for replacing the alternator. Thanks.
White850Turbo
Year and Model:
Post by White850Turbo »
Removal
Preparations
-Disconnect the battery lead.
-Detach the pipe from the control module box.
-Remove the auxiliaries belt according to Replacing the auxiliaries belt / belt tensioner .
-Remove the power steering pump and place it on top of the engine. To remove the power steering pump, see Replacing power steering pump .
Without AC
-Remove the upper screw from the upper mounting.
-Remove the lower screws.
-Disconnect the warning lamp positive lead and the connector from the generator (GEN).
-Pull the generator (GEN) upwards / away.
With AC
-Remove the upper screw.
-Remove the screws common to the generator (GEN) and compressor; the lower screws on the generator (GEN) and the upper screws on the compressor.
-Raise the car.
-Slacken off the lower screws for the compressor (so that there is some clearance).
-Remove the air baffle.
-Lower the car.
Installation
Without AC
-Position the generator (GEN)
-Connect the and cable the connector.
-Position the generator (GEN) and install the upper screw loosely.
-Install the lower screws. Ensure the generator is correctly positioned before tightening. Tightening torque 25 Nm (18 lb.ft).
-Remove the screw and nut that run through the upper mounting. Tightening torque 25 Nm (18 lb.ft).
With AC
-Position the generator (GEN).
-Install the screws common to the generator (GEN) and compressor; the lower screws on the generator (GEN) and the upper screws on the compressor loosely.
-Raise the car.
-Tighten the lower screws for the compressor. Tightening torque 25 Nm (18 lb.ft).
-Install the air baffle.
-Tighten the screws common to the generator (GEN) and the compressor. Tightening torque 25 Nm (18 lb.ft).
Carry out the remaining operations in reverse order.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
