bulb failure position light warning light is on Topic is solved
[email protected]
Post by [email protected] »
I have checked all the lights but no failures seen anyone know what this means?
Viper_7
Post by Viper_7 »
Are the front amber marker lights and the rear Red lights in the side of the rear lamps.
It's been known that the warning has extra sensory perception and can tell when a bulb is about to fail...other times it just has a bad day.
Some people have posted before saying a good slam of the boot clears it!
If all looks well, I'd just reset the message with the rest button on the stalk..and see if it comes back,
Vipes
shu
Post by shu »
how do you replace the bulb, I did a quick check, seems you have to tak out the bolt, from rear speaker cover ?
Viper_7
Post by Viper_7 »
The rear bulbs are accessed form the boot / trunk.
You'll note each side a compartment with a handle...just unlock...open the compartment..and the bulbs are easily accesible. There's two seperate bulb holders...with each bulb having a locking pin...there's not bolts etc?
Vipes
