I am sure this has been asked prior to this but could someone tell me how to reset the message,maintenace overdue and shut off the i,I know it will be all one procedure I just don't know it.
Thanks
Maintenance overdue message
jimgrames62
- Year and Model: 1999 s80
found this on sweedespeed.com hope it works?
Here's the procedure for your model; 08 c70
1) Turn Ignition key to position I.
2) Press and hold trip counter reset button.
3) Turn ignition switch to position II.
4) Continue holding trip mileage button for about 10 seconds.
5) After SRL flashes, release trip mileage button.
6) SRL should be reset.
Be advised, there must be at least 0.1 miles on the trip odometer or the SRL will not reset.
jimgrames62
found this on another site?
Put the key in the slot and push it in.
With one hand press and hold the odometer reset button on the instrument cluster.
With the other hand press the start button one time.
Pause for one second and then push and hold the start button (with your foot off of the brake pedal) until all of the dash lights come on.
Continue to hold the odometer reset button until the yellow triangle flashes.
It will flash four times, release the button before the end of the fourth flash.
Then turn the car off and remove the key.
Reinsert the key and start the car.
The light should now be off.
