I took my car to three different mechanics and they say my car is running perfectly.. but for some reason my check engine light is always on! I want to figure out a way to just get rid of it I don't care what I have to do. It is an eye soar for me.. Even if I have to go into the console and scrape the light sensor off of the circuit board...... any suggestions?
Thanks!
Erase CEL! 2002 Volvo S80 T6
bronson1111
- Year and Model: S80 T6, 2002
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
hahaha remove the light in the dash. Just joke
When "check engine light" is on, there is/are error code/s. Read them out and tell us the codes.
The "check engine light" is there not to make us angry, you know. I'ts there to warn us about a problem.
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
jimmy57
- Been thanked: 320 times
did any of the mechanics read codes or attempt to clear the light?
The light can be turned on by some transmission faults and the codes in trans control module has to be erased to get the lamp off.
bronson1111
Haha I know it is supposed to tell me what is wrong.. It is a code PO422 and PO420. The mechanic said it is the catalytic converter. In my state we don't have to have a catalytic converter so I am not even going to bother fixing it. The car runs fine.. I just don't enjoy looking at that light. It is embarrassing when I am driving girls around! haha
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Bad idea to keep driving it. The cats are probably getting clogged which will eventually lead to loss of performance and economy. Also, they may heat up to a point where they become a serious fire hazard.
Ignore the light if you like, but if I was you id get the cats replaced with straight pipes to be on the safe side
yuckuJackD
Just to develop the boosted5cyl's idea about the pipe - there are resonators made exactly for that reason - to replace the catalyc converter cheaper, but not making the car noisy...
I own a S40 '97, too. I did the replacement with pipe, but i couldn't drive it more than a day and put a resonator.
p.s. i'm not sure that "resonator" is the right word for that but I hope you got the idea - it's kind of silencer.
Good luck
Good luck
