Strange sound (Videos included)
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
Hello
The car is S80 2.9 2000 Manual transmission, with 230 000 km on it.
Some history: A mounth ago i went to the dealer for standart check of the suspension. I've been told there are gone bad these things:
1. Front left stabiliser link - done
2. Front left ball joint - done
3. Upper engine mount - done
4. Bottom engine mount - pending
5. Right engine mount - pending
6. Rear right shock absorber - pending
At that time I didn't hear the knocking sound. I always listen to a music loudly so it's possible to miss a suspension's bad sounds, you know :)
So, the problem: A sound like knocking coming from right, I belive. Because it's hard to explain a sound, I've done 2 videos.
Video from the right rear view mirror - here
Video from the left rear view mirror - here
The sound could be heard mostly when switching between 1-st gear and reverse. When i'm on 1-st, stop the car and go again it's almost not knocking. Same is in reverse. If i go very slowly it's possible not to hear that sound at all. Just watch the whole videos to see what I mean.
I know, the first thing you'll say is - drive shafts!
OK, but in case the shafts are gone bad I'll have such sound when making U-turns, too, right? But I don't. I made a video for that, too, (making circles in both sides) but there are alot of other sounds which makes the video useless.
However, I don't belive this sound could be because of the two engine mounts, left for replacing. In case the engine mount is the reason, the sound should be only on 1-st gear or only on reverse, or I'm wrong?
Honestly I had alot of ideas for what's wrong, but in the next few seconds i realise it couldn't be because of anything else.
One more - you'll give me an advice to do what the dealer says - replace the two engine mounts and see if it will fix the problem. OK I will but latter - it's not the right moment for such shopping :oops: and I have other things to bay, too - tires for example. I'm just trying to figure out what is gone bad, so i could plan when to fix it.
Thanks to all of you for your advices.
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
jimmy57
Been thanked: 320 times
Post by jimmy57 »
It sounds like spline crunch to me. I have had that noise, or at least it sounds like the audio of the clip, and used anti-seize on the splines in the bub. I have never been crazy about the 10mm bolt holding the shaft in on the 99 and later stuff that uses it.
You could snap out center cap, remove the bolt and spray penetrating oil into the splines and then put bolt back and drive to see if that is it.
yuckuJackD
Thanks
I will do that next weekend.
