ABS light on, no codes, but no ABS either
robk46
Year and Model: 1997
Post by robk46 »
Hi all, just bought a '97 850 Wagon 2.4 N/A. The ABS light is on, and I've verified the ABS does not function, but my code scanner says I have no codes. Is there an ABS troubleshooting guide, or should I go straight to soldering the ABS module?
Thanks.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
You cant pull ABS codes with a standard code scanner.
95% of the time it is the ABS Module. The other % is usually the wheel sensors. It is up to you where you want to start.
'98 S70 T5
2016 Chevy Cruze Premier
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
There are only two kinds of '96 and later 850 ABS modules - those that have failed or those that are going to fail. After they are properly repaired they usually hold up for the rest of the life of the car. If you can solder you can fix it yourself our you can do a swap with member Matty Moo for not a ton of money.
robk46
Post by robk46 »
Thanks guys. I'll start with soldering the ABS module. Then off to find the oil leak. . .I hope it's not the rear main.
darag2358
Year and Model: 1999 V70R
Post by darag2358 »
Honestly, I would just have MattyMoo do it and save the hassle of trying to pry open that stupid thing and resealing. He's super cheap, his work is good, and dealing with him is easy.
robk46
Post by robk46 »
Fixed! Took all of 20 minutes to remove, solder, seal, and put back in. Thanks guys!
