Is there a common failure trend with these? A search didn't turn up much info.
Mine is showing lines out in the info display but then if you change the content the text looks fine but here may be old data still trying to show through in other pixels or off to the side where it shouldn't be like a ghost image. bottom line the display, connections or computer are on the fritz and I"m curious if this is a simply swap, reprogram needed or a complicated R&R.
info message display erratic
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
JRL
- Year and Model: Several
- Been thanked: 16 times
You probably need a new DIM module
(Dash)
Not hard to do but pricey
(Dash)
I may have seen posts about people replacing gauge displays due to faulty gauges...is this the DIM? or is the DIM just the small info display? (driver info management or such)?
I"m curious if I can just swap with a used one? I know every Saab 9-5 had a info display that failed due to poor connection with the LCD met the IC board and several techs made a living repairing these. Anything similar?
EDIT: OK DIM looks like the entire gauge pack:
http://shop.ebay.com/i.html?_from=R40&_ ... Categories
I guess having an R one wouldn't be a bad thing...but I don't have a 2004!
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
- 312 Views
Last post by MoVolvos
- 9317 Views
Last post by natural4reelz
