bad oil leak on c70
fats_40
Year and Model: c7o 2001
bad oil leak on c70
Post by fats_40 »
hiya i have a c70 with a bad oil leak at rear of engine,but i cannot find where its coming from,ive had car up in the air on axle stands and put it in drive so i could look for leak.cannot find it anywhere.any ideas please thanks. oh car has150,000 miles and is a 2001 model auto
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
What I would do is clean off all the oil that has gotten on the engine, run the car for a little bit and then take a look again to see if you can see where the leak is coming from. Without cleaning up the oil, it will be very hard to find the leak.
tigmaned
Year and Model: blacked-out V70 04
Post by tigmaned »
one thing that might have started this issue???
have you checked your (PCV) volvo calls it a flame trap system.
a quick test- with engine running, take off oil filler cap, with your hand covering the opening you should feel a little sucking from the engine. if its pressure comeing out that might be part of your problem? engine pressure is finding another way out from a old gasket??
