1996 850 central door lock actuator
christhekiwi
Year and Model: 850 Turbo X 2
Post by christhekiwi »
The drivers door lock began to work internittently and has now failed - the key turns but fails to lock or unlock to the drivers door. If the key is used at the trunk or the passengers door it unlocks the car but not the drivers door. I have removed the door complete (to JB weld fix the door restraint mount on the A pillar) and have the handle off and the lock/latch unit out.
The lock actuator is a separate unit and can be removed from the lock/latch unit.
My question is are these actuators compatible across any other models of the same year E.G 440's?
I have limited junkyard options and can't seem to find these on any of the sponsor part sites.
Cheers
