98 v70 door lock actuator failure
98v70dad
- Year and Model: 98 V70
- Has thanked: 1 time
I have replaced two failed lock actuators already. Is there something simple that goes wrong with them that I can fix myself or am I better off just replacing the unit. When I try to lock or unlock the failed one it sort of tries to go up or down and wiggles a little bit but the actuator just doesn't have the umph to push it up. All of them have failed like this.
JRL
- Year and Model: Several
- Been thanked: 16 times
They pretty much all fail at one time or another
- Has thanked: 311 times
- Been thanked: 817 times
It is super common, like JRL said. The actuators can be rebuilt, if you search the forums you will find info on it but you may have to wade through a lot of posts as it is such a common problem. As I recall the gist of the fix is to order the little motors on eBay and swap them out.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,
I have a problem with one of mine already too. This is really strange though.
When unlocking using the driver side switch, the little button thing goes up but then comes back down again, so the door doesnt actually unlock. If i press it again and hold it, it might unlock.
I havent tried it with the passenger side switch though, if there is one, but i can pull it manually up no problem.
JRL
It's still a lock/actuator failure
- 17 Replies
- 3679 Views
Last post by sleddriver
- 2327 Views
- 2587 Views
Last post by erez321
- 24 Replies
- 6497 Views
Last post by cn90
- 2029 Views
Last post by TrstnBrtt
