abs and tracs light on most of the time
keepersboy
- Year and Model: v70 1998 850t 1994
My abs and trac light is on almost always. It sometimes will be off for a short while after re-starting engine.. O yeah, its a 98 v70 glt. I have cleaned the wheel sensors, and nothing changed. I'm not getting any codes when I scan it, but understand many code readers won't pick up abs problems. How do I know if its a bad abs module? I guess I'm asking for suggestions on where to go next.. The car also has 136k miles . Thanks
- Year and Model: Many Volvos
- Been thanked: 76 times
In reality there are only two kinds of '96 and on ABS modules - those that have failed and those that are going to. Since you have cleaned the wheel sensors you are in the 99% probability camp for a failing module.
Member Matty Moo will do a rebuilt on an exchange basis and for a very right price:
https://www.midwest-abs.com/ABS_Modules.php
If you know how to solder you can fix it yourself. I have a writeup here:
https://www.matthewsvolvosite.com/forums ... hp?p=46827
keepersboy
I got the abs module from midwest-abs. It took about 1 hour to do only because I dropped a torx bit and could not find it. Otherwise about a 1/2 hour job. Thanks for all the advice, fixed my problems.
swede_speed
- Year and Model: 850, 1997
you could just take the bulb out of the instrument cluster for the ABS light as I did....cheap fix ---don't need ABS anyways---car runs fine without it. Also not needed for state inspection.
1997 855 Wagon
"Light travels faster than sound. This is why some people appear bright until you hear them speak."
— Unknown
— Unknown
- 22 Replies
- 6059 Views
Last post by hausmeister
- 64 Replies
- 9101 Views
Last post by greg850r
- 15 Replies
- 6642 Views
Last post by BoomerFT
- 2482 Views
- 1418 Views
