1997 850 wont start
Car ran then wouldnt start (very hot weather) Next day car started, drove home. Hasn't started since. Engine turns. No spark at coil. Coil is ok. crank shaft sensor ok. fuel ok. Could it be associated to the anti-theft alarm system?
keepersboy
- Year and Model: v70 1998 850t 1994
Do you have a check engine light? Check for any codes. A bad cam sensor can shut you down
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
On US-spec cars, the alarm system completely deactivates the starting circuit. No starter, no nothing.Could it be associated to the anti-theft alarm system?
If you have no spark, I, too, would be looking at the camshaft sensor. This is one of those things that you might want to find in the junkyard before purchasing a new one just to swap in to try out.
'98 S70 T5
2016 Chevy Cruze Premier
- 1229 Views
Last post by whtwgn
- 1279 Views
Last post by Azik09
- 25 Replies
- 8722 Views
Last post by AmericanT4
- 402 Views
Last post by gswede
- 1136 Views
Last post by obayha
