Hi folks. Just got a very clean 86 740 and everything works (!!!). Brake job done in June.
However front wheel bearing issue arose. The OEM parts include a single piece hub and rotor. The R Front bearing is shot. I have been quoted $385 from Meineke which tells me that they are going to replace the front rotor and hub etc. Another shop has told me $147 for the bearings part and 2Hrs installation costs ($90 per hour).
There is a retro fit kit to the two piece hub and rotor (post 1988). I am wondering if any of you have done the work and what the steps are to do it. I am thinking of both sides in the front since this will homogenize the parts and future service and as well, cost me about the same or even less.
Thoughts?
86 740 Front Wheel Bearing
Always do right. It will satisfy some people and astonish the rest--- Twain
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
VADIS shows a brake disc kit, #5 on the attached, which would appear to solve your problem.
The note alongside the number says. "270876, spare part version." I have checked the part number on the Volvo Wholesale Parts site, above, and it lists it as, "Wheels and front suspension - Front suspension - Hub and rotor - W/o abs. Girling Back 1985 - 1987." It also lists, "Wheels and front suspension - Front suspension - Hub and rotor - W/o abs. Dba, 14" Back 1983 - 1987. Obviously you would need to know if you had Girling or DBA brakes.
I would suggest that you contact them for more help on this in case I am reading VADIS wrong.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
