hi newbi here and to volvo ownership. i have a problem :(
beamo
Year and Model: v70 2003
Post by beamo »
hi guys i am new here and am after some advice. i have just bought a v70 d5 which drives lovely but when i am slowing down coming to a junction or dipping the clutch there is an almighty high pitch squeal coming from what sounds like the right hand side of the engine.? now when i aam accelerating and the engine is under load it dosent squeal at all?????
i seem to find aswell that if i put the air con on it makes it better ??
any help or ideas would be appreciated.
thanks :?
c70_lindsay
Year and Model: 99 S70 T5.
Post by c70_lindsay »
Have you checked the serpentine belt? That would be my first guess.
brandonbeach14
Year and Model: 2.4T V70, 2001
Post by brandonbeach14 »
I would try belt dressing from what you're describing. It will likely help if the belt id loose at idle speeds. Look closely at the belt for wear and cracks. If the belt breaks, you'll be stranded.
beamo
Post by beamo »
c70_lindsay wrote:Have you checked the serpentine belt? That would be my first guess.
sorry new to volvos where can this be found??
cheer
beamo
Post by beamo »
brandonbeach14 wrote:I would try belt dressing from what you're describing. It will likely help if the belt id loose at idle speeds. Look closely at the belt for wear and cracks. If the belt breaks, you'll be stranded.
could you tell me what you mean by belt dressing???
cheers
Susans_Volvo
Year and Model: V70 XC AWD 2000
Post by Susans_Volvo »
cheers
Oooh! Oooh! I know this one! "Belt dressing" is something you put on a car's belt to help reduce squeaks and squeals. It comes in both spray cans and in little packets of liquid. In the states it's easy to pick up, often in little packets at the checkout area of an auto parts store like AutoZone. Don't SOAK the belt with it, use as little as possible (you can always add more).
But if the belt shows wear or cracks or splits you do need to have it replaced. Dressing is only a short term fix.
Has thanked: 312 times
Been thanked: 818 times
And the serpentine belt is visible from the passenger side of the engine compartment. It wraps around (and runs) the power steering pump, alternator, and air conditoner compressor.
