2000-04 S40 Block Heater Installation
1996 - 2004 S40
1996 - 2004 V40
Tracerec
Year and Model: S40, 2003
Post by Tracerec »
Hi all,
I'm a Volvo newbie having recently purchased a 2003 S40 in excellent shape with low mileage from California and imported it into Canada. I love the car but was shocked when the local Volvo dealer quoted me over $700 Cdn to install a block heater. Searching the net I found a few parts suppliers that sell the block heaters for around $25. Is there something difficult about installing the block heater in the 2003 S40? If it's relatively simple can someone tell me where the block heater plug is located?
Thanks,
Dan
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hi Welcome to MVS.
Haven't heard of a block heater yet!! Do you mean a heater core? If so they cost a lot more than $25, around $125 for an OEM Behr brand and from what I've heard the entire dashboard needs to be removed to replace it.
$700 Cdn doesn't seem that bad if this is what you need. Unfortunately there are no write-ups on MVS yet. Try Volvospeed.
Tracerec
Post by Tracerec »
Thanks for the response. I suppose you don't have much need for block heaters in Melbourne :D . A block heater is a small electrical element that plugs into the engine block through an engine core plug (frost plug) and heats the engine coolant. They're used in regions with cold climates. Where I live in Canada they're considered standard equipment for a vehicle.
I was hoping someone could tell me where the core plug is located.
Cheers,
Dan
A couple of the forum members from the colder regions discussing how thay deal with their cooling issues...... https://www.matthewsvolvosite.com/forums ... er#p169655
Also this one on block heaters for the 850s/V70s. https://www.matthewsvolvosite.com/forums ... =1&t=32050
Hope this helps
