Hi all,
I'm a Volvo newbie having recently purchased a 2003 S40 in excellent shape with low mileage from California and imported it into Canada. I love the car but was shocked when the local Volvo dealer quoted me over $700 Cdn to install a block heater. Searching the net I found a few parts suppliers that sell the block heaters for around $25. Is there something difficult about installing the block heater in the 2003 S40? If it's relatively simple can someone tell me where the block heater plug is located?
Thanks,
Dan
2000-04 S40 Block Heater Installation
precopster
- Year and Model: Lots
- Been thanked: 128 times
Hi Welcome to MVS.
Haven't heard of a block heater yet!! Do you mean a heater core? If so they cost a lot more than $25, around $125 for an OEM Behr brand and from what I've heard the entire dashboard needs to be removed to replace it.
$700 Cdn doesn't seem that bad if this is what you need. Unfortunately there are no write-ups on MVS yet. Try Volvospeed.
Thanks for the response. I suppose you don't have much need for block heaters in Melbourne
. A block heater is a small electrical element that plugs into the engine block through an engine core plug (frost plug) and heats the engine coolant. They're used in regions with cold climates. Where I live in Canada they're considered standard equipment for a vehicle.
I was hoping someone could tell me where the core plug is located.
Cheers,
Dan
Cheers,
Dan
precopster
A couple of the forum members from the colder regions discussing how thay deal with their cooling issues...... https://www.matthewsvolvosite.com/forums ... er#p169655
Also this one on block heaters for the 850s/V70s. https://www.matthewsvolvosite.com/forums ... =1&t=32050
Hope this helps
Hope this helps
