1992 Volvo 240 wgn- Gear shift lever will not release
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
hunterbaye
Year and Model: 98 V70
Post by hunterbaye »
I am purchasing a 1992 Volvo 240 Wgn. with only 134k miles
The owner states that after the car sets overnight you can't get it to go into gear without reaching by the shift lever and release some button.
Help please-
I don't want to purchase it if that is a major problem.
Thanks
Jeff
[email protected]
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is not necessarily a major problem. For some reason the inhibitor switch is not releasing.
1. It may be as simple as fuse #7 has blown. This fuse also covers the brake lights and ABS. If the brake lights are working the fuse is OK.
2. The inhibitor switch has moved out of alignment. Re-aligning it is easy.
3. The inhibitor switch may need replacing. A little more fiddly but still a DIY task.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
