PVC Oil Trap leaking 1999 S80
mikeyfood
Year and Model: s80, 1999
Post by mikeyfood »
have a slow/slight oil leak. dealer can't find problem. suggested starting with changing breather box, seals, etc...come to find out that 'breather box' is code for PVC Oil Trap or Flame Trap. parts cost $120. labor is 7hrs at $116 per hour. Any ideas for me? I'm new to this w/volvo dealerships and not liking it too much.
Appreciate anything anyone is offering....
D_V_ENT850R
Year and Model: 850R 1996
Post by D_V_ENT850R »
If you order the kit from IPD it comes with instructions! Intake comes off easy enough plus you may need to replace your brake booster hose while your under there.
mikeyfood
Post by mikeyfood »
THANKS!!! Any idea how long it takes?
D_V_ENT850R
I would say maybe 5 hours. The hardest bolt is the one on the bottom of the intake! The dipstick and that one are a little difficult but other than that not bad! I would say remove the throttle cable to prevent damage to it! Just so you know the bolts where the intake bolt to the head only loosen the lower ones the intake is slotted and slides right up and off!
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
I suggest a test to check the condition of your PVC. If it is clogged, excess pressure will occur. To test, remove the oil dip stick and observe if there is excessive pressure pushing out while revving the engine. If the PVC is blocked, there will be pressure pushing out. If there is suction, you're in good shape- no need to replace it at this time.......
