Oil leak from VVT or Cam Seal?
mlanctot
- Year and Model: 1999 S80T6
Re: Oil leak from VVT or Cam Seal?
You mean the cap on top of the engine? Where you fill her with oil.
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
Yeap! I didn't start replacing mines until this year. Not sure if the dealer did it during maintenance service. I now have no more spark plug cover and oil around my oil cap. With a flatblade screwdriver, pry out old, pop in new one...that simple.
98 S70 T5-M Brick for life
iRenaissanceMan
- Year and Model: 2010 XC70 T6
Did you find the solution to your oil leaking problem? Was it simply the rubber seal on the oil cap or did you find it was crankcase pressure and re-did pcv system?mlanctot wrote:You mean the cap on top of the engine? Where you fill her with oil.
Thanks
