small air hose broke causing evap code S70
nickdeary
Year and Model: 1998 S70
Post by nickdeary »
Hi Guys,
I kept pulling an evap code and got under the hood and realized that a small hose had dry rotted and ripped but i cant figure out what the hose is called. It is a small cheap hose that goes from the EGR to the right side of the instake manifold. It also has a 1 way air valve on it that I broke trying to get the hose off. I need a new one but cant figure out what its called.
Thanks!
Nick
Juan62
Year and Model: S70 T-5M 1998
Post by Juan62 »
If its the one near the power steering pump and right of intake manifold= vacuum hose. here is a list below.
PI-318 VACUUM ELBOW INSTALL GUIDE.pdf
(169.71 KiB) Downloaded 84 times
98 S70 T5-M Brick for life
