1991 volvo 240 Air Box Thermostat?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
norge777
Year and Model: 850 1996
Post by norge777 »
I want to change the AIR BOX THERMOSTAT. Flap inside is barely open in the warm 80 degree temp.
Do I just grab and pull straight up on the old Thermostat? Then press the new one in by hand?
Or do I have to remove the whole AIR BOX and maybe depress the spring I see inside to remove?
Cannot find that much info on Google concerning this procedure. (1991 VOLVO 240).
Many thanks for any info.
norge777
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The airbox thermostat when functioning properly will have no effect on you in FL. It is supposed to close at 50F so that unheated air is admitted. I would not spend the money. Pop it out and fasten door closed to the hot air hose fitting with a sheetmetal screw or drywall screw. The risk to Mass Airflow Sensor is not worth it when it does no good for preventing throttle freezing and reducing emissions.
