A few days ago my wife got stuck with car with a dead battery. When she came home I tried to find the cause. I discovered the overhead lights (central and 2 lateral ones) would not turn off few seconds after door(s)
were shut! As probably the problem went unoticed for days the battery got discharged...I guess...
I manually pressed the pin on door post on all four doors with light switches on proper position and lights stayed on in all cases.
However with driver's door open and key in the ignition once I pressed the pin the door chime stopped ringging...
Fuse that protects circuit (Nbr 5) is OK.
Any ideas?
Tks
87 740 INTERIOR OVERHEAD LIGHTS
