87 740 INTERIOR OVERHEAD LIGHTS
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
BEMFICA1
Post by BEMFICA1 »
A few days ago my wife got stuck with car with a dead battery. When she came home I tried to find the cause. I discovered the overhead lights (central and 2 lateral ones) would not turn off few seconds after door(s)
were shut! As probably the problem went unoticed for days the battery got discharged...I guess...
I manually pressed the pin on door post on all four doors with light switches on proper position and lights stayed on in all cases.
However with driver's door open and key in the ignition once I pressed the pin the door chime stopped ringging...
Fuse that protects circuit (Nbr 5) is OK.
Any ideas?
Tks
pgrilo
Post by pgrilo »
the timer relay simes to be bad. Tira as lampadas fora
