1998 V70- Should I change Transmission fluid?
DukeONuke
Year and Model: 1998 Volvo V70 XC
Post by DukeONuke »
Anybody have a link to a copy of this:
http://www.ipdusa.com/uploads/sku_files/7945_INST.PDF
The above link is dead. Or a copy they can email or post for me.
Much Thanks!
Duke
cn90 wrote:Do NOT use the power flush.
What I did was:
- I use Mobil ATF (Synthetic). You will need about 10 qts.
- Disconnect Upper Cooler Hose, run engine and drain through it (run engine until bubbles come out).
1- Add 3qts through dipstick. Repeat draining through upper cooler line.
2- Add 3qts through dipstick. Repeat draining through upper cooler line.
3- Add 3qts through dipstick. Repeat draining through upper cooler line.
1. See this DIY by IPD-USA:
2. After completed, place a screw-type clamp around the factory clip holding the cooler line. This clip has a tendency to come out with time. NOTE the smaller end of the clip faces the radiator.
DukeONuke
Post by DukeONuke »
Is there some pictures or a tutorial anywhere to show me how to do the drain and fill on transmission of my 1998 V70?
I don't know what lines are the transmission fluid lines. Thanks All.
Pauloil
Year and Model:
Post by Pauloil »
look under the car and find 24mm drain plug. loosen and remove when still warm. let fluid drain. refill fluid, about 3.5qt. use new gasket, same as alum. oil plug gasket. check level repeat next oil change.
99 V70XC 158K
95 850glt 188K
keepersboy
Year and Model: v70 1998 850t 1994
Post by keepersboy »
I followed the tutorial on flushing by " madeinjapan" and it worked great. flushed about 10 qts through. Both cars seemed to shift smoother after flush
baukewolters
Year and Model: v70 2000
Post by baukewolters »
I bought a v70 2.5D from 2000 with 358.000 km, and an automatic gearbox that worked, but rattled and slammed, especially when switching at about 80 km/h. The Volvo garage that sold it to me aknowledged the problem at the sale, said they could do nothing about ist but switching the entire gear box. But it would still hold out 70.000 km or so.
At 405.000 km I had it power flushed, since then it workes like new. The stuff coming out of the gear box was the "worst the mechanic had ever seen", he said. Now at 455.000 km it is still all running smoothly as new. Going for the 500.000!
joe_pinehill
Year and Model: 850 1996
Post by joe_pinehill »
I use a mityvac to pull out a couple quarts from the drain, then refill with exactly was removed.
96 850 GLT
RIP '90 240 DL, 285K, someone ran a stop sign in front of me
RIP '89 760 Wagon, 200K
RIP '83 240 Wagon, rusted out
