Man am I having a heck of a time getting off the 36mm nut
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Nuttydriver wrote:I used a 3/4 breaker bar and a six foot pipe and was picking the car up off the ground before it finally broke loose.
Archimedes has a lot to answer for :D
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Put the wheel on the ground and then get a big freakin pipe. Or a shop will spin it off for you with an impact wrench for cheap ($5) and then put it back so you can get it off.
Beware, the torx ones are also a PITA. I broke 2 socket wrenches on those little jerks.
'98 S70 T5
2016 Chevy Cruze Premier
Been thanked: 504 times
Post by cn90 »
JDS60R wrote:Don't lower the car on it. Put the bar to the right and jack up the bar.
As much as I like your idea of putting the Iron Pipe to the Right (see pic I posted above) and jack it up. The problem is: you may get the nut off or you may raise the whole car up!
So, I always place the Iron Pipe in such a way that whether I loosen or tighten the nut, the Iron Pipe always goes downward.
JDS60R
Been thanked: 3 times
Post by JDS60R »
My idea was for those without a cheater bar like the OP.
I personally use an air ratchet Ingersol Rand 1/2in with 625 reversing ft/lbs. It removes them all easily.
Retired
obayha
Year and Model: V70 1999 Base
Post by obayha »
Are all axle nuts 36mm?
Mine seem to be 30mm..
Just wondering
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
jblackburn
obayha wrote:Are all axle nuts 36mm?
Just wondering
Just a guess, but they were probably replaced with aftermarket ones at some point. My original ones were shot at 128K.
'98 S70 T5
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Update: tried for a couple hours again last night: no progress.
I tried jacking the bar up, then lowering the car onto the bar on a jackstand. Nothing worked. I'm just going to take it to a shop and have them remove the nut, then replace it. I have a pipe that just a bit too small for the end of the breaker, which is oblong. Tried even to hammer the pipe into a similar shape, no dice.
My next trip to a hardware store I'll come out with a propane torch, I guarantee you.
That breaker bar was so warped from the weight I thought if something gave way something would go through a wall. I have a photo I'll post later. I had on safety goggles, heavy clothing, got out of the way as much as possible to where I thought the shrapnel would fly, and almost put on my hockey helmet and pads.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Just wondering
I've read about these being 30, 32, 34 and 36mm.
To others: I wouldn't assume what yours is until you measure it.
Also -> Amazon link
obayha
Post by obayha »
Thanks,
Was just wondering that when I get new axles if I need new nuts or that the outside dia. doesn't matter..
Hope you are successful in your adventure.
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
Just stating the obvious here...you did unstake it right? I have a $30 Kobalt impact that ripped thru that (since upgraded) but doing it by hand it probably would need to be unstaked before you twist it off.
Staked axle nut Volvo 850 36mm
Also I do own a 36mm Craftsman socket (Craftsman 36mm only comes in shallow 12 point), but my SK 36mm 6 point deep is a better fit. Not sure if you are using a deep or shallow socket but the shallow won't go all the way on the nut, and you risk buggering it up. FYI Advance Auto Parts "rents" deep axle nut sockets with 36mm in it (IIRC) for $50 but you get your $$ back when you return it.
SK 36mm axle nut impact socket
sk socket.jpg (109.4 KiB) Viewed 1473 times
In addition, you just need to go buy an iron pipe. Take your breaker bar with you to Home Depot and get one. They are fairly cheap.
36" breaker bar
36" breaker bar
breaker bar.jpg (124.47 KiB) Viewed 1473 times
1995 850 GLT Wagon w/ 200,000 miles
