89' 240 - Coolant leaks
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Science
Year and Model:
Post by Science »
Hello again,
Awhile back I noticed some coolant leaking in 2 places.
-On the top of the water pump where it meets the chamber on top of it.
-The passenger side of the Engine, the rear of the engine behind the 4th spark plug a bit below it.
Pretty frequent now. Im basically "spotting"
89 240dl aka "The Chill Factor 5000"
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
On top of the pump where it meets the cylinder head there is a small seal, part #8 on the attached.
240 cooling system.pdf
(163.23 KiB) Downloaded 171 times
For the leak near the #4 plug it could be the head gasket or one of the pipes leading to the heater.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Science
Year and Model:
Post by Science »
Gotcha, thx so much!
Science
Year and Model:
Post by Science »
Well,
I cleaned off the areas I believe the leaks originate from and tried to start the car.
It wants to start like always but just cant hold the pressure Im thinking. Checked plugs
and cleaned suspected surfaces. I can see oil crying from the head seal below the 4th plug.
I can see the radiator fluid seeping out of the head seal right behind the water pump.
And the last visible weep is from the engine cap above the thermostat...
So theres that, sounds like about 1,200$ of work ...
Science
Year and Model:
Post by Science »
Gearing up for the job.
I don't think i want to spend that kind of money on this. It looks like "Time" is
the real enemy here ....
Great videos to help out -
