HU-615 to aftermarket Head Unit
How to integrate your phone into your Volvo's audio. Which speakers to buy to replace old ones. Recommended head unit brands and models... This is where we talk watts, ohms, GPS, iPod integration, component installation, tips, tricks and advice for making your Volvo's audio, video, ticket avoiding and mapping gadgets work better than ever... iPod, XM, GPS, DVD, Speakers, Amps, Radar Detectors
This topic is in the MVS Volvo Repair Database » HU-615 to aftermarket Head Unit: Volvo V40
zulu-v40
Year and Model: 2003 V40
Re: HU-615 to aftermarket Head Unit
Post by zulu-v40 »
Above is the factory head unit that came as part of the premium sound system. Like you said, the adapter I used will not work for your car. You could install a head unit using the parts I listed, but it won't sound very good, and doesn't solve the adapter issue. I had no idea there were different versions of the HU-615. Pretty interesting.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
I'm sorry - I was unclear. There is only one version of the HU-615 head unit. The whole overall installed system is different.
I don't recall the exact specific items but its like this (this is a montage of different years so some specifics may be different)
Basic system : HU-6xx 8 speakers
Performance system: HU-6xx 8 speakers + 200w amp + subwoofer
Premium system: HU-8xx 11 speakers + 300w amp + subwoofer + center channel w/ surround sound
I think the Premium only included the HU-8xx series because it needed the center channel output. If you have the HU-6xx and a subwoofer and amp then you might have the performance system not the premium.
Again, this is sort of fragmented info based on my three different systems so it might be a little different on your year/model
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
zulu-v40
Post by zulu-v40 »
The picture Qhoove posted shows only an 8 pin adapter and is labeled 615. The picture I posted shows 6 and 8 pin adapters and is an HU-615. It seems like there might be different versions. Unless, Qhoove, do you have something other than the 615? That's one thing that has never been addressed in this thread.
fazool
Post by fazool »
I re looked at the OP picture and the label does say 615.
I think maybe that pic above is a 650 - it looks like mine and as I recall, the 615 might not support the external amp, but I dont recall.
Qhoove
Year and Model: v40, 2001
Post by Qhoove »
Hey guys, the head unit is definitely an HU-615, I'm mainly trying to install this headunit so I can install a subwoofer, so I had already planned on installing an external amp, with the adapters (besides Autoleads PC9-414 Wiring Harness Adapter) could I still install the new head unit, or will I still need a DIN adapter?
fazool
Post by fazool »
Again, I am doing this from memory.....and a montage of my experience with my HU-650 and my HU-615 and my other-year S40, so I might be a little foggy on my details.
OK,l so the HU-615 has two DIN connectors. One is a 6-pin and thats for the pre-amp outputs. The other is an 8-pin and thats for external MelBUS accesssories (CD changeer, satellite receiver).
If you want to feed pre-amp signals to an external amp, you need the 6-pin DIN connector. The pin-outs aer in the diagram below.
This head unit does not include the center channel or a sub channel output so you will need an external amplifier that can separate those channels. You probably want a 5-channel external amp or a 4-channel amp with pre-amp outputs to daisy chain a second sub amp.
