PNP replace or clean?
NewToVolvo850s
Year and Model: 1995 850 Turbo,GLT
Post by NewToVolvo850s »
My PNP switch is giving me problems.
-No reverse lights
-Cant go over half throttle
-Shifts weird
-Dash lights shut off when I go into drive
Should I replace it with a shop or clean it myself? Which is safer? This is my DD and wont be able to get around to it until this weekend
1995 Volvo 850 Turbo 270HP
1995 Volvo 850 GLT 185HP
Autocross Love
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
Are you able to pull any codes? Seems like the problems are more then the PNP.
Regardless; I'd crack it open and clean it up. I read a write-up a while ago and it seems that the hardest part of the job is removing everything from the car to get at the thing in the first place.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
NewToVolvo850s
I have no way to pull up codes. I will get autozone to do it tomorrow. How long of a job is cleaning the PNP switch? Is it better to clean it than replace it? Is it difficult?
Autocross Love
Has thanked: 311 times
Been thanked: 817 times
I have cleaned the PNP before. Getting to it is some work, took me 2 hours on an NA. Then pulling and cleaning another hour, couple hours to put it back together.
If you are going to clean it, you really must get replacement copper contacts. They wear out and get crooked, usually only one or two of them wear out but this is usually the problem, more so than just dirt and crud. There are three contacts in the switch. The best route is to get a PNP that someone is junking, or from a yard. Take it apart before you take apart your own. Then you'll know what to do with yours. Keep the best 3 contacts overall when you put yours back together, it will be good to go a long time.
There is a writeup on this site for cleaning.
I think replacing is faster and easier than cleaning/rebuilding, but also a lot more expensive.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Purely from a monetary standpoint, I'd clean it first. If that doesn't work, the 2nd time around is always much easier.
'98 S70 T5
2016 Chevy Cruze Premier
NewToVolvo850s
Thank you guys. What else could cause these problems I am having?
Autocross Love
jblackburn
The PNP switch sounds like it could be the cause of most of these - the dash lights may/may not be an ignition switch (try jiggling your key).
A bad throttle position sensor can also sometimes account for bad shifting, BUT you also have the symptom of no reverse lights. I'd try cleaning and re-aligning the PNP switch (there's a trick using a mirror behind the car, or having a helper to yell at you when you get it into the "R" position and the lights come on really helps).
'98 S70 T5
vjaneczko
Post by vjaneczko »
If you're talking about the '95, you can pull codes with the breakout box in front of the ECU box, behind the passenger headlight. Do a quick search for tips.
The Volvo PNP is $176 and the ScanTech is $91 but I'd stay away from ScanTech due to their poor quality.
FCP Transmission Parts
2006 S60R - For ME!
waynej
Year and Model: 1999 S70
Post by waynej »
I cleaned mine a few years ago and it's still doing fine. Total time R&R and clean was less than 3 hours. I just turned copper contacts over to get new surface instead of replacing.The problem is it comes packed full of grease which gets hard over the years and prevents contact. I removed all grease and flushed with solvent, then re-lubed with synthetic grease.
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
NewToVolvo850s
I started removal today and worked on it for 2 hours until dark and almost have it all the way out. I will clean it tomorrow and reinstall and align wednesday. hopefully this fixes my problems before the weekend.
Autocross Love
