ok so i have 223 code from A1 socket
http://www.volvospeed.com/Repair/Electr ... cketA1.php
this tells me my TPS is bad
http://au.geocities.com/OZBRICK850/comp ... volvo.html
this one tells me air control valve
What should i do??
can someone check Haynes and other stuff and see what they getting
pretty much saw TPS code where i looked nothing about idle air control valve
was told that this is mistaken code or whatever
Need to make move (TPS or AIr control valve)
HELP me PLEASE
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Sorry that I somehow missed this. Okay, here's the thing. I'm thinking that one code is setting the other. I'm not sure if the air contol valve would set a throttle position sensor, but I'm thinking the TPS could cause the air control valve to act irratic. Plus I don't hear of the ACV being replaced very often at all, but I do hear of the TPS being replaced fairly often on these board. I'd go for the TPS first and hopefully that will take care of the other code. Good luck and tell us how things go.
Volgrrr
- Year and Model: '95 T5 wagon
What should i do??
can someone check Haynes and other stuff and see what they are getting pretty much saw TPS code where i looked nothing about idle air control valve
I just happened to be looking around through some of the old stuff on this forum and came across your query.
I assume this problem has been resolved by now, however, your confusion wouldn't have occured if you had comprehended the information right in front of you own eyes.
So, I'll let you in on a little secret which may help you in future.
You ask - "What shall I do?"
And here is the simple answer:
READ THE INFORMATION YOU GET ACCURATELY
You blithely mixed oranges with apples, then ask for help and, while others are scratching their heads in confusion, then respond with the insulting "Seriously, this forum is so DEAD".
Just in case you don't realise what I am trying to point out, here it is.
A1 deals with auto transmission fault codes (i.e. 2-2-3 being throttle position too low)
Ozbrick clearly identifies their answer applies to socket A2 which, funnily enough, is the fuel system (i.e. 2-2-3 IAC signal absent or faulty).
So in future, please do not vent you spleen on those who do not understand your misleading post.
This is an excellent forum for getting excellent information - let's keep it that way.
There are only two types of car owners - those who own Volvos and those who wish they did.
CarVolvo
- Year and Model:
I think matt's site rules too!
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
