new member /1992 940 gl won't start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bbkraigsley
Year and Model: 940 gl 1992
Post by bbkraigsley »
Hi; I am a new member to the Mathews forum. My 1992 940 gl with 278,000 mi died the other day. I changed out the distributor cap & rotor but that didn't help. Fortunately, my golfing buddy is good friends with Shane here in Salisbury and they came over to look at it.
Appears the timing belt has a flat spot-3" or so.
Can anyone suggest what I should do while I have the timing belt off. There is some oil around the nut on the timing belt pulley as well as the tension pulley. Also, can anyone recommend a site that describes how to change the timing belt.
I love this car and don't want to junk it just yet.
Bill
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I moved your post to the RWD forum where you can get better answers to your questions.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Timing belt renewal on the B230 engine is quite straightforward. The attached has the instructions:
940 timing belt renewal.pdf
(504.63 KiB) Downloaded 326 times
Some things extra from experience:
When you remove the fan line the inside of the radiator with thick cardboard to stop any wrenches or other bits going through when they slip. At least one will.
The hardest part of the job is removing the crankshaft bolt. You will see that a Volvo tool, part #5034 is specified for this. There are many other methods bandied about on the internet but using the correct tool is the safest, and quickest, way of doing it. The crankshaft pulley sits on a small key in the crankshaft. The more violent methods of loosening the bolt can break the key, making the job very expensive. If, as you say, you are going to keep the car it may pay to buy the proper tool. Our sponsor IPD has them at $49.95. This link takes you to the listing.
If you can work steel or know someone who does you can find plans for a home made tool here.
If you don't know when the tensioner was last replaced I would advise that you do this now.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
obayha
Year and Model: V70 1999 Base
Post by obayha »
Is this an interference engine?
If so, This motor has been turned over many times while trying to figure out the problem and was wondering if damage has already occurred? The first part of the PDf file states to align timing marks before removing belt or valves may contact pistons.
Don't want anyone jumping into something if there is a lot more then meets the eye.
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
writer100
Year and Model: 940 1994
Post by writer100 »
it is not an interference engine--there will not be damage.
1994 Volvo 940: 189,000 miles.
2008 Mustang GT convertible: 10000 miles. The garage queen.
billofdurham
If it is the 8 valve engine it is non-interference. The 16 valve engine is definitely interference.
Bill.
Previously:
