95 850 radio advice
Year and Model: Many Volvos
Been thanked: 75 times
Re: 95 850 radio advice
Post by Ozark Lee »
For the code you need to talk to your dealer. If the radio is original to your car they can give it to you based on the VIN number but many radios have been swapped out and they will need the serial numbers off of the top of the radio to get the proper code. In my case I just use a Sharpie and write the code on the top of the radio - look for a hand written 4 digit number somewhere on the radio after you pop it out.
dimasp
Year and Model: 850 glt 1995
Post by dimasp »
AGAIN, THANKS !
Dimas
3903davis
Year and Model: 850 nt, 94
Post by 3903davis »
could anyone help with locating a code for an sc-811 serial # 840619858.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
You have to contact a dealer. Also, look on the chasy, it may be written on there. Four digits all numbers are 6 or below.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
MadeInJapan wrote:All of the SC's will work in your car as long as they're hooked up right and all wiring is good.
Can you elaborate on this? Like what the part is called etc so I can poke around for it. This allows one to have an MP3-like device connected all the time? Selected by pressing the button for multi cd thing (which I do not have)? I use a very antique RCA Lyra MP3 player connected to one of those cassette things. It works OK, but the CD connector solution sounds cleaner.
Thanks
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
Post by rmmagow »
MadeInJapan wrote:Or....you can do my solution: USA-Spec adapter (direct connect through the CD changer input on the back of all SC's...controlled by the SC!). Crutchfield sells them and I see them on eBay too...you'll need the Volvo cable with it.
Actually I meant to quote this :-( Sorry.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
This link may have something you can use in your research:
https://www.matthewsvolvosite.com/forums ... 33&t=44268
