How to drain gas tank 02-S60
sergio
Year and Model: S60 2002
Post by sergio »
My gas tank is full. I need to drain it to less than 1/4 in order to replace the fuel level sensor with burnt contacts.
This 02 S60 won't start so I can't just drive, and I don't have a lift.
Is there any particular way to do it ?
Would a drill pump and a hose do?
Is the emptied gas reusable?
Thanks
S60 2002 180K miles looks and runs like new (except when sulking)
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
Certainly drained gas is reusable. Just drain it into safe and compatible containers. You need a place to store about 12-15 gallons. Be caustious using a drill pump. Drills spark a lot in the motor and you are going to have lots of gas and fumes around.
You are better off going to a place like Harbor Freight and buying a cheap siphon hose with built in squeeze pump and one way valve for under $10. While there get of three 5 gallon containers.
WHy are you draining the tank anyway? Isn't the level under the rear seat like the fuel pump? Accessible through a sealed trap door in the floor under the rear seat?
I changed my fuel filter and have had my rear seat out several times but I dont remember.
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
sergio
Post by sergio »
Thanks fazool. The level sensor is indeed in the left hole, just under the seat. The right hole (the pump itself) is higher. That suggests the the top of the tank is higher than the left hole. Si with a full tank, if I open this hole gas will pour out. I remember having seen a picture of the tank and it seems kind of crescent shape. I don't dare open it when full.
Thanks for the very good suggestion.
rjS60Turbo
Year and Model: 2002 S60
Post by rjS60Turbo »
I wonder if your problem is causing mine: engine shuts off at a 1/4 tank, like its out of gas. Wont start back up until I put in at least 2 gallons. I know its not empty (or even close) because a subsequent fill-up takes 13-16 gallons.... its a 21 gallon tank. Thoughts? Thanks, Rj
Sardine
Year and Model: V70 2.5T 2004, S60 2
Post by Sardine »
Are you trying to drain the tank to reduce the risk of explosion. if you are, then the quesion is: Is a full tank or a half-filled tank safer from risk of explosion? Does anybody know for sure? This link http://around-us-facts.blogspot.com.au/ ... never.html says that a full tank is safer.
