(2001 Volvo S60 2.4T) Acceleration Problems
jamiedustin
Year and Model: 2001 S60 2.4T
Post by jamiedustin »
Ive used this site for many repairs to my volvo and have had to finally ask a question as i cannot find an answer on here and am wondering if anyone has had the same problems with their vehicle.My car is the 01 s60 2.4 turbo and has had a problem with accelerating under load for about the past month and has gotten worse over time.I use a program called mitchell to read what the codes on the Snap-on scanner i use. I am getting codes that state problems with:
-Evap Canister Shut-off Valve
-Long term Fuel Trim
-Front heated oxygen sensor (HOS2)
The problems are that when accelerating the car will not shift from one gear to the next which is the point of high RPM's ; it will just do a very large bounce back and fourth 3-4 times before accelerating very rapidly and then doing the same thing when going to the next gear. Also when travelling at speed and the throttle is released or lowered the vehicle does not want to accelerate when pushing the pedal again. I have recently replaced the Throttle body Module as this showed on a recent scan and have had the codes erased and the codes above are the codes remaining when i drive the car for another day. also the front o2 sensor has 0V which i have been told by the garage may be caused by a short circuit or broken o2 sensor.
PLEASE give me any suggestions considering everyone is saying just sell the car..
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
I would count to 10 very slowly before I sell the car; this could all be due to a bad Engine Management Relay (including the ETM-related symptoms). Could you list the exact DTC codes that you pulled? (Sorry, I've never used Mitchell)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
regent
Post by regent »
2015 BMW 335i
jamiedustin
could you explain what the DTC codes were ? and im also planning on replcing he O2 sensors front and back as the front sensor is reading no voltage.
