1998 S70 T5 290k/miles.
Could not read the check engine light code at the local parts store, so I went to the Volvo dealer (US$126 HOUR !) though they read it at no charge. They did not say what the code was, but told me it was the throttle position sensor and that they wouldn't have time to repair it that afternoon (I had not asked them too). Does it take a long time?
I've never cleaned the PCV system and it has never exhibited any problems.
What is the throttle position sensor and where is it? Other than this sudden appearance of the check engine light the vehicle runs fine.
Thanks in advance,
Jerry
Throttle Position Sensor
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
It does exactly what it sounds like - senses how much your foot is down on the gas. The car uses this information to determine air/fuel mixture and auto transmission shift patterns.
It's on the very front of the throttle body.
'98 S70 T5
2016 Chevy Cruze Premier
I can't see anything familiar on my S70, which is a 5-speed. Is the stick shift different or is the switch buried beneath the accelerator cable unit?
(Yes, they use lots of winter salt up here in Wisconsin)
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
The TPS is mounted on the opposite side of the TB shaft. Its black plastic attached with 2 screws as in the pic posted by jblackburn. You'll probably need to remove the intercooler hoses to see it clearly. Since there is so much salt on the roads in your area, you might get away with simply disconnecting the plug and cleaning the oxidation on the contacts with some fine grit sand paper. Then reset the codes and see if the problem comes back.
Ambitious but rubbish
bigdaddylee82
- Year and Model: '95 850 GLT+94 parts
Try what tjts1 said before ordering a new one. Pull the current one off, get a can of CRC Contact Cleaner (or similar) a wire brush, and go to town on the contacts on the sensor and it's cable. When you put it back together use some dielectric grease. I'm 90%+ sure that'll fix it. If it doesn't, you'll want to clean the cable contacts and use dielectric grease on the new one anyway, so nothing to loose for trying.
- Lee
- Lee
