99 Volvo S80 no power
driver1234567890
- Year and Model: 1999
I have a 1999 volvo S80 t6. Whenever I hit the peddle hard or just going up a hill the car has no power and will just stay around 2000 rpm and flacuate a little. I replaced the fuel filter and it worked fine for about 5 miles. Now its back to no power. I also have a o2 sensor code that im fixing this weekend. I'm not sure if that can be related or its something else. Pease help. Thanks.
driver1234567890
I just looked up and I have codes p0056,p0158,p1174,p1184. I know the first two are for th o2 which I'm fixing today. But I don't think that'll fix the loss of power. Do thes codes help thanks for replying.
driver1234567890
I replaced the 02 and it fixed the o2 sensor code, but still no power. I think im going to check the fuel pump next.
StL_PoopyPants
- Year and Model: S80, 2001
This post is way old and you might not see it but I'm sorry to say, it sounds like the transmission. If it's not keeping it's speed you are likely counting down the days that thing has left. Plus a bad transmission really puts wear on the engine.
driver1234567890
Sorry for the late response but it ended up being ba fuel. I filled it up with fresh fuel and it improved instantly. Thanks for all the help.
- 3650 Views
Last post by Terrible2004s80
- 1599 Views
Last post by matt5112
