99 s80 no power
driver1234567890
- Year and Model: 1999
99 s80 no power
I have a 1999 s80 t6, and it has no power on the highway and going up hills. I changed the fuel filter and it ran great for about 5 miles, then it went to no power again. so I changed it again and the same thing happened, it ran great for about 5 miles. I checked the fuel pressure and its great. Any suggestions.
- osman
- Year and Model: 2002 c70 hardtop
Lack of power could be many different things.
Any codes or other symptoms?
Noises. smells, sounds?
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
99 XC70 AWD LPT 115
driver1234567890
No noises. But every time I use a new filter it runs fine for about 5 miles could the fuel filter keep clogging. I bought bad gas and ever since then
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
How do you define bad gas?
When you change out the filter, do you try blowing thru the filter to see if it is plugged? i.e. with your mouth but careful not to ingest any gas... I imagine compressed air would have to much pressure i.e. would overcome any 'plugging' so would not be 'fair' test?
driver1234567890
I did blow the filter in reverse. but I just added a full tank of gas and it seems to be running 90% better. Just loss of power on extreme peddle acceleration. I think all it was, was bad gas. And i ment bad gas because i bought gas from the rundown gas station because it was cheap. not doing that anymore.
dcarlson12
I actually meant to try blowing in the direction of the flow to see if there was any resistance possibly caused by the filter media being plugged with dirt/debris. Glad to hear it seems to have been solved with fresh gas.
- 3658 Views
Last post by Terrible2004s80
- 9 Replies
- 2569 Views
Last post by mika
