89 740 rough Idle(non turbo)
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
nisan17
Year and Model: 92 940 turbo
Has thanked: 2 times
Post by nisan17 »
Hi Esteemed group,
The last couple of months my check engine light has been on. The engine still runs smooth. Until recently, when the engine is warm, and upon pulling up to a stop sign or stop light there is drop in rpm to the point of almost stalling, then it idles rough at about 500-700rpm. I've also noticed that there are exhaust soot spots in my drive where the car warms up in our cold Wisconsin Winters. Can one give me an idea what is causing this? If I can have the system scanned where Is the connector? I can't seem to find it under the dash on the driver's side. :?:
Thanks much in advance,
Kevin
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Kevin,
The On-Board Diagnostic unit is in the engine compartment. You do not need a scanner. The instructions for its use are pinned at the top of the forum.
Usually on these engines when the idle is jumping around the throttle body needs cleaning. However, as you have a check engine light, read the codes first.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
nisan17
Post by nisan17 »
Thanks Bill.
Kevin
nisan17
Post by nisan17 »
Bill, If I checked the OBD correct, the code gave "Throttle Switch" Now what? I'm going to clean the throttel body and reset the OBD.
Kevin
billofdurham
Kevin,
If the code was 1-3-3 or 2-1-3 you can only check the throttle switch itself. The attached tells you how:
740 throttle switch check.pdf
(112.71 KiB) Downloaded 258 times
Cleaning the throttle body will do no harm.
Bill.
Previously:
nisan17
Post by nisan17 »
Bill, how is the throttle switch replaced? It's running pretty rough, actually more so after cleaning the throttle body.
Thanks,
Kevin
billofdurham
Before spending money on a new switch you can run two checks on the switch itself to see if it is working.
1.
(112.71 KiB) Downloaded 185 times
If it is working try adjusting the switch.
2.
740 throttle switch adjustment..pdf
(65.83 KiB) Downloaded 169 times
To replace the switch remove the two retaining screws and the electrical connector. Replacing is, as they say, reverse of the above but the switch will need to be adjusted.
Bill.
Previously:
nisan17
Post by nisan17 »
Thanks Bill. As soon as we dig out I'll test same.
Thanks again,
Kevin
nisan17
Post by nisan17 »
Bill, is the throttle switch the same as a "TPS"? One supplier calls it a "Throttle Position Sensor" TPS. I just want to make sure.
Thanks again,
Kevin
Kevin
billofdurham
Some call it a throttle position switch, others a throttle position sensor. Either way it is abbreviated to TPS. They are one and the same.
Bill.
Previously:
